Forerunner 220/620: Acquire a GPS Fix Message
The Forerunner 220 and 620 need to acquire a GPS signal to set the Real Time Clock (RTC). This clock is used to perform most functions on the watch.
If you attempt to use the device before acquiring satellites you will get one of these messages:
  • Acquire a GPS fix to start timer
  • Acquire a GPS fix to access the menu
To eliminate the message follow these steps:
  1. Take device outside.
  2. Ensure device is on and says Run.
  3. Wait until device acquires satellites.
    • Stay in an open area with a clear view of the sky to acquire satellites quickly. This process should not take more than 5 minutes.
You should now see the green bars on the device to indicate you have acquired satellites and can use the device as intended.
