Wireless Map and Software Update Instructions
A wireless connection to home high-speed internet (Fiber, Cable, DSL, etc.) is required to successfully complete a Wi-Fi update.
  • Connections with data caps or restrictions should not be used due to the size of a map update
  • Slower connections (satellite, fixed wireless, dial-up, etc.) and mobile broadband (MiFi, AirCard, cell phone tethering, etc.) should not be used
  • Not all captive portals will be compatible with Garmin devices
NOTE: See Not Enough Free Space for a Wireless Update if your device states there is not enough space for the wireless update.
Video to Learn about Wi-Fi Connections for Updates
Video Instructions for Map and Software Updates
Camper/RV 785 Update Instructions
dēzl™ 780/dēzlCam™ 785 Update Instructions
Overlander® Update Instructions
NOTE: Not all devices come preloaded and/or are compatible with the maps below.
Current Map Version: 2026.20 (North America) as of June 25, 2025.
Current Map Version: 2026.20 (Europe) as of May 28, 2025.
Current Map Version: 2024.10 (Middle East and North Africa) as of September 8th, 2023
Current Map Version: 2026.10 (South America) as of May 7, 2025.
To Check For and Install Both Software and Map Updates on This Device:
1. Plug the device into a power source
2. Touch  or
3. Touch About Device
4. Touch System Updates
5. Touch Access Wi-Fi Settings if prompted. Skip to step 10 if your device is already connected to a wireless network.
6. Enable Wi-Fi by touching the toggle switch and changing it from Android - toggle disabled Off to Android - toggle enabled On if prompted.
7. Select a wireless network. A network labeled Garmin is shown as an example. Select your personal wireless network.
8. Enter the password for the network if necessary
The device should then connect to the network. The network will be added to the list of saved networks. The device will reconnect to this network automatically when it is within range.
9. Press the  back arrow
10. The device will check for any available updates over a Wi-Fi network. Any available updates will be displayed on this page.
Press Map to view information about and start the map update. Press Software to view information about and start the software update.
    • iOverlander data will be listed as a map update
      • Only compatible with the Overlander® and RV 785
Press Download, then OK to begin downloading all updates.
NOTE: The device will be unusable until the updates complete.
See Troubleshooting Wireless Updates on an Automotive Device if the device encounters any problems with the wireless update.
You may also update your device by using Garmin Express.  See  Updating Automotive Maps and Software with Garmin Express.
Related
