Ordering a Replacement Transom Mounting Bracket for a Garmin Transducer
Garmin does offer replacement transom mounting brackets for transducers. Before ordering the mounting bracket, verify what transducer is being used as there are different brackets for different transducers.
There are a two ways to determine the type of transducer being used.
Find the Garmin part number on the transducer. To find this number, locate the white sticker attached to the transducer's cable. This sticker should be located on the end of the cable with the connector. This is the opposite end of the cable that the transducer is on. This sticker should have a number on it that begins with 010- (e.g. 010-10249-00).
Find out which transducer is being used by looking at the transducer itself. Some transducers, if made by Airmar, will have an Airmar part number molded into the plastic. Some examples of Airmar part numbers are P23, P32, or P66.
If the transducer has an XID or Garmin ID wire, its model can be found using the following steps:
Begin on the Home screen
Select Sonar
Select Traditional
Press Menu
Select Sonar Setup
Select Installation
Select Transducer Diagnostics
Contact Marine Product Support to order the part. Search by the device to find the contact information. These transom mounting brackets cannot be purchased online.
