Contacts and Sending Messages with the Garmin Explore App
The Garmin Explore™ app can be paired and used with a compatible inReach® device to send messages to SMS numbers, email addresses, and inReach addresses.
You can manually enter these numbers or addresses when composing a message, but to save time you can also:
Use your smartphone's contacts
Create contacts on the Garmin Explore app
Create contacts on your paired inReach device and sync them to the Garmin Explore app
You can also sync your smartphone's contacts to your paired inReach device. This is helpful for trips when you will not be bringing your phone with you, or in case the phone's battery becomes depleted.
This article provides steps for all of these, along with how to send a message using the Garmin Explore app.
IMPORTANT: Ensure your phone or tablet and inReach device are connected before attempting to send a message. You can confirm this on the Garmin Explore app by selecting the devices page at the bottom of the app. For steps on how to pair your inReach handheld with a phone or tablet, see Related.
Create Contacts on the Garmin Explore App
Open the Garmin Explore app.
Select the profile icon in the top left.
Select Explore Contacts.
Select .
Select Create New Contact.
Select any of the required fields (in red) to enter information.
Select Save when done.
The contact should now be saved in the Explore Contacts, and also appear when you select the To: field while creating a new message.
Create Contacts on the inReach Device and Sync Them to the Garmin Explore App
Alpha® 200i and 300i Dog Tracking Handheld
From the home page, touch Setup.
Touch .
Touch Contacts.
Touch NewContact.
Touch an item to edit.
Enter the new information and touch when finished.
Repeat steps 5 and 6 to enter additional contact details.
Touch Save when finished.
GPSMAP® 66i, 67i, 86i, and 86sci Outdoor Handhelds
Press MENU twice to access the main menu.
Select Setup.
Select Contacts.
Select New Contact.
Select an item to edit.
Enter the new information and select Done when finished.
Select Save when finished.
GPSMAP® H1i Plus Outdoor Handheld
Press MENU twice, then select to access the apps list.
Select Contacts.
Select New Contact.
Select a field to edit (e.g. First Name).
Enter the new information, then select to return to the previous page.
Repeat steps 4 and 5 to enter additional contact details.
inReach Mini 2 Handheld
From the home page, press OK to open the main menu.
Select Contacts.
Select Add Contact.
Enter the new information.
Select Done when finished.
Montana® 700i, 710i, 750i, and 760i Outdoor Handhelds
Touch to access the main menu.
Touch .
Touch Contacts.
Touch New Contact.
When finished adding contacts, you need to sync the device with the Garmin Explore app so they transfer to the app. For steps, see - Syncing the Garmin Explore App.
Adding Phone Contacts to an inReach Device Through the Garmin Explore App
Select .
Select Import System Contact.
You may need to grant permission for the Garmin Explore app to access your phone's contacts.
Select a contact.
Edit contact details, if desired.
If you have duplicate contacts in your phone, you need to select between multiple phone numbers and/or email addresses.
If this happens, select the desired phone number and/or email address then select Next.
Select Save or Done.
Select to return to the previous screen.
Perform steps 4-12 for any additional contacts.
After the contact is created, syncing from the Devices page will transfer the contacts to the inReach device.
For how to then send a message from the inReach device, see:
Select Open System Contacts at the bottom of the screen.
Select a contact.
The selected contact will populate in the To: field.
Add any additional contacts.
Select a type of message at the bottom of the screen.
Touch the inReach Message field to manually type out a message.
-or-
Touch to select a Quick Text.
Select to send the message.
The message should send to the selected recipients, provided the paired inReach device has a clear view of the sky.
Sending a Check-In/Preset Message in the Garmin Explore App
NOTE: Check-in messages have replaced preset messages as of September 27th, 2022. inReach® accounts set up prior to this date will still have preset messages available, but any new accounts created after this date will use check-in messages.
Check-in/Preset messages are a convenient way of sending messages to a predefined group of family and friends Check-In/Preset messages cannot be changed on the Garmin Explore app or the inReach device.
