Garmin Devices Not Compatible with BaseCamp
BaseCamp™ software supports a wide range of Garmin devices. However, there are some specific devices that are not compatible with BaseCamp, which are listed below.
Garmin Serial Handhelds
Legacy Garmin devices that communicate with the computer through a serial port are not compatible with BaseCamp.
  • eTrex® Basic
  • eTrex® H
  • eTrex Vista™
  • eTrex Legend™
  • eTrex Venture™
  • eTrex Mariner™
  • eTrex Summit™
  • eTrex Camo™
  • Foretrex® 101 and 201
  • Geko™ 201 and 301
  • Rino® 110, 120, and 130
  • GPS 72 and 76
  • GPSMAP® 76 and 76S
  • GPS 12, 12MAP, 12CX, and 12XL
  • GPS II™
  • GPS II+
  • GPS III®
  • GPS III+
  • GPS V™
Use MapSource to communicate with a device in this list. If you encounter a "Previous MapSource Not Found" error this can be resolved by installing BaseCamp first, then running the MapSource install file again. While these devices are not directly compatible with BaseCamp, installing the program will load the necessary background files required for MapSource to install and run on the computer.
The Trip and Waypoint Manager software that was included with the retail purchase of many of these devices has since been discontinued and is no longer available.
Garmin Automotive Devices
  • BaseCamp will display "Unsupported Device Connected"
dēzl Devices
To send locations or coordinates, use the dēzl™ app.
  • dēzl™ LGV620 | dēzl™ OTR620 GPS navigators
  • dēzl™ LGV720 | dēzl™ OTR720 GPS navigators
  • dēzl™ LGV820 | dēzl™ OTR820 GPS navigators
  • dēzl™ LGV1020 | dēzl™ OTR1020 GPS navigators
  • dēzlCam™ LGV725 | dēzlCam™ OTR725 GPS navigators with camera
Tread Devices
To view and share your data, use the Tread® app.
  • Tread® 2 GPS navigator
  • Tread® 2 - Overland Edition GPS navigator
  • Tread® 2 - SxS Edition GPS navigator
zūmo Devices
  • zūmo® XT2 GPS navigator
inReach® Satellite Communicators
The following devices are not compatible with BaseCamp, but can be used with the Earthmate app and the Garmin Explore™ website to manage routes, waypoints, and tracks.
  • inReach Mini
  • inReach Mini 2
    • The inReach Mini 2 is not compatible with the Earthmate app, but can be used with the Garmin Explore app and the Garmin Explore website.
  • inReach Explorer®+
  • inReach SE®+
  • inReach Explorer®
  • inReach SE®
  • inReach® Original Devices (inReach for PN-60w, inReach for Android, or inReach for Smartphones)
Garmin In-Dash Navigation Systems
Garmin BaseCamp is not compatible with planning routes or sharing locations with Garmin in-dash navigation systems.
