Creating, Activating and Deactivating Tracked Devices on the Alpha 200 Plus or Alpha 300 Series
Activating Groups or Dogs
An Active device is one that is being tracked and will show on the map, and dog compass. You can activate groups or individual devices.Activating a Dog
- Select Dog List
- Select the dog you want to activate
- Tap toggle for it to turn blue
Activating a Group
Activating a group will activate every collar or contact in that list.
- Select Dog List
- Select [Group Icon]
- Select the group you want to activate
Deactivating a Dog
- Select Dog List
- Select the Dog you want to deactivate
- Tap toggle for it to turn grey
Deactivating a Group
Deactivating a group will deactivate every collar or contact in that list.
- Select Dog List
- Select the group you want to deactivate
- Tap Toggle for it to turn grey
Creating a Group and Adding Dogs or Contacts
- Select Dog List
- Select the group icon
- Select Create a Group
- Enter group name
- Select Add Device
Removing Dogs, Renaming Groups and Deleting Groups
- Select Dog List
- Select the group you want to manage
- Select
- Manage Group: Allows you to remove or add dogs/contacts from the group
- Rename: Allows you to rename the current group
- Delete Group: Removes the group but does not remove the dogs/contacts from the dog list.
