If the issue persists after signing into an administrator account, the application itself can be run as an administrator.
To Run the Application as an Administrator:
1. Right-click on the application icon (BaseCamp or MapSource)
2. Click Properties
3. Click the Compatibility tab
4. Ensure Compatibility mode is unchecked
5. Select Run this program as an administrator
6. Click Apply
7. Click OK
These steps should allow the program to open and use the maps normally.
Follow these Steps if the Above does not Resolve the Locked Maps.:
Uninstall the map from the computer. See Uninstall Garmin Maps from the Computer for instructions.
Windows Only: Run Garmin Express as an Administrator:
The error may be caused by permissions issues for Garmin Express. Running as an administrator may resolve this:
