Garmin Express Fails While "Downloading Files" to an Outdoor Handheld
Garmin Express™ software connects to the Internet to download software, map updates, and downloadable content for Garmin devices. Internet connectivity and network connection issues can prevent Garmin Express from downloading this content. Symptoms of these issues may include:
  • There was an error installing the update error message
  • There was an error installing the content error message
  • The update failed due to a server connection issue error message
  • No visible progress over time (Update stuck or update frozen)
  • The progress bar periodically lowers to an earlier value
Progress Bar
If any issues occur during the "copying files" stage of the update, including those listed above, see - Garmin Express Fails While "Copying Files" to an Outdoor Handheld.
If you have purchased a downloadable content (DLC) map in the past, and are attempting to activate a new purchase of the map in Garmin Express, see - Garmin Express "Unable to Activate Your Purchase" for an Outdoor Handheld.
Items to Check
Garmin Handheld USB Connectivity
Ensure the Handheld Recognizes the Connection
Most handheld devices will display a USB icon on the screen indicating that the device is communicating with your computer. If you do not see this, make sure to select Yes on the handheld if prompted to go to Mass Storage.
Outdoor Handheld Mass Storage Mode Icon
If the handheld still does not recognize the connection, see - Outdoor Handheld Device Not Detected by Garmin Express for additional troubleshooting.
Close Other Applications That Might Be Actively Reading or Writing to the Garmin Device
  • Devices can only be actively read by or written to one application at a time.
  • For example, if Garmin BaseCamp™ software is currently reading and caching the pre-installed map from your device, Garmin Express software will not be able to write to your device.
Internet Connectivity and Related Settings
IMPORTANT: A high-speed Internet connection such as DSL or cable is required to use Garmin Express. If you are unsure what type of internet connection you are using, check with your Internet Service Provider (ISP).
Things to Avoid
Using these types of computers or network connections can introduce many obstacles that can prevent a successful download. If any of the following items cannot be avoided, attempt the download again later on a different computer or network.
  • Virtual Private Network (VPN)
  • Work computers and/or networks
  • Public Wi-Fi connections
  • Mobile broadband (such as a 4G/LTE or 5G MiFi, AirCard, or cell phone tethering)
  • Satellite internet
  • Fixed wireless internet
  • Dial-up internet
When Using a Wi-Fi Connection, Ensure You Have a Strong Signal
  • Try moving the computer closer to the Wi-Fi router if possible.
  • If you are still unable to get a strong signal, try using a computer that is plugged in with an Ethernet cable.
Ensure Your Data Limit Is Not Capped/Throttled by Your ISP
  • Many of Garmin's downloadable map products are several gigabytes (GB) in size.
  • Some ISPs will place a limit on how much data may be downloaded during a daily or monthly cycle.
    • Depending on the ISP, exceeding this limit could result in reduced Internet performance or fees for the additional data used.
  • To find out whether your internet service is capped/throttled or restricted, contact your ISP before contacting Garmin.
    • If your internet service is being capped/throttled or restricted, the map update download will take longer to complete and may appear frozen at times.
    • Asking your ISP to remove the capping/throttling or restricted download may be an option.
Reset the Network Hardware
  • Shut down the computer and reset the network hardware by unplugging the router and/or modem.
  • Bypass the router by connecting the modem directly to the computer.
  • After one minute, plug the modem back in to restart it, turn the computer back on, and try the update again.
Check the Proxy Settings on the Computer
Temporarily Disable Internet Security/Firewall
  • Although most security software will not interfere with Garmin Express, some security software (such as software that is used on work computers or in a business environment) may cause errors in Garmin Express.
  • If possible, try temporarily disabling the software.
    • If you cannot disable it, it will be necessary to use a different computer.
  • If disabling fails to resolve the issue, you can set up an exception for Garmin Express.
  • See Garmin Fleet Updater and Garmin Express Network Requirements for more information.
  • For advanced users: Check for any bandwidth limiting settings on the router such as Asus QOS.
Garmin Express Troubleshooting
Ensure Garmin Express is Up to Date
Ensure the Computer has Enough Free Disk Space
  • Maps contain a lot of information that must be downloaded to your computer before installing it on your device. Some downloads can require up to 20GB of available disk space to install successfully. If you receive the error message "not enough space on computer, this computer does not have enough space to download the update." You will need to free up additional space on your hard drive.
Ensure the Date, Time, and Time Zone Settings are Correct on the Computer
Windows Only: Run Garmin Express as an Administrator
The error may be caused by permissions issues for Garmin Express. Running the application as an administrator may resolve this:
  1. Locate and right-click the Garmin Express icon in one of the following locations:
    • Search for Garmin Express in the Start menu.
    • Find the desktop shortcut Garmin Express Icon (if present).
  2. Select Run as Administrator or More > Run as Administrator.
Uninstall Garmin Express, Restart the Computer, and Reinstall Garmin Express
  • Restarting the computer (see below) can often shutdown other programs or applications running in the background as well as clear temporary memory which may be interfering with the process operating normally. If that does not resolve your issue, continue with the steps below.
  • To uninstall Garmin Express, see - Full Uninstall of Garmin Express.
  • To restart the computer, follow the steps below. Shutting down, pressing the power button, or closing the lid on a notebook computer may not effectively restart the computer on some operating systems.
    Restarting the Computer
    Windows 8.1 and higher
    1. Right-click the Start button.
    2. Click Shut down or sign out.
    3. Click Restart.
    Windows 7
    1. Click the Start button.
    2. Click  next to Shut Down.
    3. Click Restart.
    MacOS/OS X
    1. Click the Apple icon in the menu bar.
    2. Click Restart...
    3. Click Restart to confirm.
  • To reinstall Garmin Express software, see - How Do I Install Garmin Express?.
These steps should resolve the issues that prevent content from downloading in Garmin Express. If these steps do not resolve the issue, visit the Garmin Express section of the Support Center to search for other Express topics.
