Transducer Models: PS30 & PS31:
These transducers provide a LiveVu sonar image with the traditional sonar feel to the imaging and 3-D views.
Panoptix Transducer | Installation Option | External Sounder Module | CHIRP Traditional & ClearVu | LIVESCOPE Forward/Down | LIVESCOPE Perspective Mode | LIVEVÜ Forward | LIVEVÜ Down | REALVÜ 3D Forward | REALVÜ 3D Down | FRONTVÜ Forward | REALVÜ 3D Historical |
PS31 | Trolling Motor Shaft/Pole or Transom | N/A | ✔ | ✔ | |||||||
PS30 | Transom Mount | N/A | ✔ | ✔ | ✔ |
PS30
LiveVu Down: Provides real-time moving sonar images. You can see fish swimming toward or away from the boat. You can see small bait fish and large target fish swimming around, as well as your lure.
RealVu 3-D Down: Allows your boat to remain stationary and still see things in 3-D around your boat. It shows history of only one sweep.
RealVu 3-D Historical: Used for finding fish while your boat is moving. This shows the entire water column you have passed over in 3-D, from the bottom surface and all of the fish in between.
PS31
LiveVu Forward: Updates the entire view with a single ping and has more of a "live video" look, providing real-time, moving sonar images. You can see fish swimming toward or away from the boat. You can see small bait fish and large target fish swimming around as well as your lure as you reel it in.
RealVu 3-D: Updates a slice of the 3-D volume with each ping and takes 1 to 4 seconds to update the entire volume. It shows the bottom and fish in the water column coming toward the boat. It sweeps forward and then history on the screen is only one sweep.
