LiveTrack Show Course Feature in the Garmin Connect App
Show Course allows a user to share with others their planned course in a LiveTrack session. Followers can view the user's real-time location as well as where they will be riding or running.
With the feature enabled, the viewer will see a magenta outline of the course the user will be traveling. A blue dot will represent the user's current location and as the user completes their activity, a blue line will represent where they have been.
LiveTrack Course Sharing Example:
Map of Route
Enabling LiveTrack Show Course in the Garmin Connect™ App
NOTE: The following steps presume you have previously paired a LiveTrack compatible device to the Garmin Connect app.
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Safety and Tracking.
  4. Select LiveTrack.
  5. Under SUPPORTED DEVICES toggle Show Course on.
LiveTrack Share Course toggle screenshot from app
If the option is not listed to turn this feature on, it means the device does not support this feature. Some devices may require a software update in order to be compatible with the Show Course feature.
Related
