Using Smart Lock With a Garmin Watch
When setting up Smart Lock on an Android® phone, your Garmin® watch will need to be allowed access as a Bluetooth® trusted device on the phone. During the pairing process, the phone should prompt you to set the connected Garmin watch as a trusted device. If you do not receive this prompt or if you want to set it up later, refer to your phone's user manual for steps to add a trusted Bluetooth device.
Once a Garmin watch is trusted by the phone, the phone will unlock without using security credentials while the watch is in range.
Smart Lock is an Android feature; for further information or assistance, refer to your phone manufacturer.
NOTE: If you do not see your Garmin watch as an option to be added as a trusted device, it is not compatible with this feature.
