Differences Between Maps on Pre-programmed Data Cards and Downloadable Content
Maps for Garmin devices are sold as pre-programmed data cards, or as a direct download from the Garmin website.
NOTE: Before selecting your purchase option:
  • Review the Requirements tab and Compatible Devices tab on the specific map product page to ensure your device and/or computer will work with the selected format.
  • Not all formats are available with all map offerings. The available formats for the specific map product will be listed under Version on the Map page.
  • On both pre-programmed data cards and Downloadable Content (DLC), the map cannot be updated. If you wish to have updated map content, a new map must be purchased.
List of Differences Between Pre-Programmed Data cards and Downloadable Content
Pre-Programmed Data CardsDownloadable Content (DLC)
  • The recommended method to purchase and use additional maps.
  • Ready for immediate use, no setup required.
  • The card can be moved between compatible Garmin devices.
  • Cannot be removed, transferred, or combined with other pre-programmed data cards or internal memory of a device.
  • The order takes an additional 1 to 3 business days to process before shipping.
  • Must be downloaded using the Garmin Express™ application and a high-speed internet connection.
  • Can be downloaded immediately after purchase.
  • Download will expire a year from purchase.
  • May be downloaded to the device, or to your own SD card if the device has insufficient space.
  • The required size of the SD card may vary depending on the size of the DLC map and on the device's card requirements.
  • For more information, see Related Content below.
  • The map may only be used with one Garmin device and cannot be transferred between devices, even if installed on an SD card.
Watch one of our video tutorials about purchasing a new map region.
microSD/SD Card
Download
Related
