How to Reset the Rino 700
There are a few instances in which it is necessary to perform a full reset on a Rino® 700 outdoor handheld, including the following:
- Not receiving a satellite signal
- Restoring the factory default settings
- Not functioning properly
The information and steps below will walk you through backing up your data and resetting.
Before Resetting
Performing a full reset can cause user data loss. User data is waypoints, routes, tracks, contacts, and geocaches.
It is recommended to back up important data with BaseCamp™ software before resetting. For steps, see Related.
NOTE: Contacts cannot be backed up and will be erased during a reset. Contacts can be re-added by accepting the prompt to save the contact once the other device has initiated a transmission.
If removing data is desired to eliminate corrupt data or free up space, see Related.
Performing a Full Reset
- Power off the Rino handheld
- Press the Menu, Enter,1 and Power buttons simultaneously
- As it powers on, Release the Power Button
- Continue to hold the menu and Enter
- Release all buttons once the Do you really want to erase all user data? message appears
- Select Yes
The Rino is now reset. You will want to take the Rino outside in a clear view of the sky for a minimum of 20 minutes to re-acquire satellite data.
1 Enter is pressing in the center of the thumbstick. It is important that the thumbstick does not move to any side, as this will prevent the reset from working.
