Top FAQs for the Tacx Speed and Cadence Sensor (Tacx Part # T2015)
Can the Tacx Speed and Cadence Sensor be used with Tacx Apps?
The sensor can be used with the Tacx Training App, Tacx Desktop App, Zwift and other training apps. However, the sensor is NOT compatible with the Tacx Utility App.
How does the Tacx Speed and Cadence Sensor communicate with other devices?
The sensor can be connected via ANT+ or Bluetooth
Does the Tacx Speed and Cadence Sensor have any indicator light to confirm it is working properly?
Yes - the sensor mounted on the bike frame is activated and turns green the moment the magnet passes the cadence sensor or speed sensor the first time. It will then illuminate every 15 seconds while the sensor is in use.
Sensor LED light
Why is the sensor indicator light not flashing?
It could be that the battery compartment holder is bent down. This way, the battery cannot get power to the sensor. Gently lift the metal plate up a little bit so that contact with the battery is improved.
Bent battery compartment contact
What type of battery is used in the Tacx Speed and Cadence Sensor?
CR2032
Are replacement bands available for the Tacx Speed and Cadence Sensor?
The Garmin Bike Mount Elastic Bands (Part # 010-11430-01) will work with the Tacx Speed and Cadence Sensor.
How to position the magnet on the spoke
The spoke magnet should align with the arrow printed on the top corner of the sensor.
Picture on the left is the correct magnet position.  The picture on the right is the incorrect position - the magnet is not aligned correctly and will not produce speed data.
Proper Magnet Position on bike   Improper Magnet position on bike
Related
