How to Install Software Updates to a Garmin DC 50 Collar
The Garmin DC™ 50 Collar software should be kept up-to-date in order to take advantage of improvements and bug fixes. Updates are free, and easy to install. Software updates can be installed through Garmin WebUpdater.
Important: This product is NOT compatible with Mac OS. Please use Windows version of Webupdater to perform updates.
- Before following the steps below, you must download and install Garmin WebUpdater
- You can follow along by watching the video below.
To Update Your Garmin DC 50 Collar with WebUpdater on Windows:
1. | Connect your Garmin device to the computer with the appropriate USB cable. Note: Avoid using USB 3.0 ports when updating a collar. | |
2. | Launch WebUpdater WebUpdater will be launched during the installation process. If you already had WebUpdater installed, launch WebUpdater. Windows: Either double-click the WebUpdater shortcut on the desktop (if available), or search for WebUpdater in your Start menu. | |
3. | Select the desired device from the drop-down menu or click Find Device if your device isn't listed. Click Next. | ![]() |
4. | WebUpdater will display the available updates. Click Next through the following pages to review the software release notes, the software change history, and the license agreement. | |
5. | Check the box to agree to the license agreement terms and then click Next to begin the update process. | ![]() |
6. | Once the update starts, WebUpdater will display the current progress. | |
7. | After installing the main update file, WebUpdater will prompt you to check for any additional updates. Click Next. | ![]() |
8. | If additional updates are available click the checkbox next to the desired updates and click Next to install them. Once complete, click Finish If no additional updates were found click Finish | |
Once complete, disconnect your device from the computer and power it on to make sure the software updates installed successfully. |
