Using the Library in the Alpha App
The Library section of the Alpha® App is where all of your data is managed and stored. You can view and edit waypoints, tracks and courses within the library. The information stored in the Library will sync across all compatible handhelds when paired and synced with the app.
For more information the Alpha app, see - Getting Started with the Garmin Alpha app
Alpha app Library
In the Alpha app select the Library tab, in the library you have four sub categories.
- All - An overview of all sections of the library shown as one.
- Tracks - Current tracks being recorded. Shows any compatible hand held tracks as well as any tracked devices.
- Waypoints - Is a marked point in which you would like to return to later.
- Saved Tracks - Track data that has been saved from a compatible handheld that is saved in the app.
NOTE: You can not save tracks with the Alpha 10 or Pro 550 Plus dog tracking handhelds.
Editing Waypoints
In the Alpha app you can edit, share and navigate the waypoints created.
Editing the Name of a Waypoint
- Select Library.
- Select Waypoints.
- Select the waypoint to edit.
- Select the Name of the waypoint to edit.
- The keyboard should open up for you to input a new name.
- Select OK when done.
Editing a Waypoint Symbol
- Select Library.
- Select Waypoints.
- Select the symbol of the waypoint next to the name.
- Select a new symbol from the available options.
For more information on Waypoints, see - Managing Waypoints in the Garmin Alpha app
Editing Saved Tracks
Tracks that have been saved on a compatible handheld and synced to the app can be edited with the app.
Editing a Track Name
- Select Library.
- Select Saved Tracks.
- Select the track to edit.
- Select the track name.
- Enter the new track name.
- Select OK to accept the new name.
For more information on Tracks, see - Editing Saved Tracks in the Garmin Alpha app
Editing a Course
Once a course has been create and saved you can go back to adjust the course later on.
- Open the Alpha app.
- Select Library.
- Select the track.
- Select Edit.
- Moving a Course - Hold and drag the point or line.
- Deleting a point - Tap on the point. Select the trash can above the point.
- Select Save when done.
For more information on Courses, see - Creating a Course in the Garmin Alpha app
