Creating Icons for Custom POIs
Custom icons can be created in most graphics editing programs and used to display the locations of custom points of interest (POIs) on the map. with POIs on a device.
When Creating a Custom Icon, the Image Must be in the Following File Type, Size, and Color Palette:
File type: .bmp.
Color palette: RGB, 8-bit or 16-bit.
Transparency color is magenta RGB: R=255, G=0, B=255.
The file name must be identical to the name of the .csv or .gpx file (e.g. 'POI.gpx' and 'POI.bmp').
After Creating the Icon, One of the Following Programs can Associate the Custom Icon With the Custom POI(s):
POI Loader
Download links and information about the POI Loader application can be found in Points of Interest (POI) Loader. Any POI files created with Garmin MapSource will require the use of POI Loader to send the POIs to your device.
Custom image .bmp files located must be saved in the same directory as the .csv or .gpx files for POI Loader to process them correctly. When the folder containing these two files is selected in POI Loader to export to the device, the .bmp icon will automatically be associated to the .csv or .gpx file that shares its name. Both the data in the .csv or .gpx file and the icon in the .bmp will be included in the .gpi file created by POI Loader.
Garmin BaseCamp™ Software
Garmin BaseCamp can add a custom icon to an individual waypoint in the waypoint properties window.
To Add Custom Icons Using Garmin BaseCamp:
Double-click a waypoint to open the properties window
Click the Notes tab
Click Add File button
Browse and select the image file
Click Open
When asked to create a new geotagged photo, click No
NOTE: Some devices are not compatible with Garmin BaseCamp.
Note: If using a computer that does not meet system requirements for Garmin BaseCamp, it will be necessary to use POI Loader to add custom POI icons. System requirements for BaseCamp can be found on our website.
