Xero A1/A1i and A1i PRO Mounting System Differences
The mounting systems for the Xero A1/A1i and Xero A1i PRO are not compatible or interchangeable..
Xero Bow Sight Mount Attachment Differences
A prominent difference between the two mounts is how they attach to the bow.
Xero A1/A1i Mount Attachment
The mount for the Xero A1/A1i is attached to the support of the bow sight. The mount is attached directly to the frame of the bow.
Xero Ai1 Mount Side View
Xero A1i PRO Mount Attachment
The mount for the Xero A1i PRO has a standard dovetail mount. One part is mounted to the bow frame and the part connected to the bow sight attaches to that already fixed mount. This provides an easy method to disconnect the bow sight for storage or transport. The Hoyt version the Xero A1i PRO can be attached by a Picatinny Rail. The same easy removal remains.
Xero A1i PRO Mount Side View
Key Feature Differences Between the Two Mounts
The Xero A1i PRO mount offers the following features not found on the Xero A1/A1i.
Micro Adjustments
All 4 primary axes are adjustable using the Xero A1i PRO's micro-adjustable rails. To learn more, see - Using the Micro-Adjustable Rails for the Xero A1i Pro.
XD Mode/Numbered rails
The numbered rails on the Xero A1i PRO provides additional aiming distance by putting the site into Extra Distance mode (XD Mode). To learn more, see - null .
Quick Detach Feature
The Xero A1i PRO can be removed from the bow using the quick detach feature. To learn more, see Detaching the Xero A1i PRO for Storage or Travel.
