How to Rearrange Icons on the inReach SE+ or Explorer+
The ability to rearrange icons 1  gives you the option to customize the inReach® handheld to your liking. Use the instructions below to rearrange icons.
IMPORTANT
This feature was introduced in firmware version 3.4. You can verify your firmware version by going to Settings, then selecting About This Device on your inReach device. If you need to update your Firmware, you can do so by performing a sync. For more information about syncing, see - Updating inReach Firmware and Syncing Account Changes with inReach Sync.
Rearranging Icons
  1. Press Menu Button.
  2. Select Reorder Icons.
    Reorder Icons Menu Selection
  3. Select the Icon you wish to move and press Check Button.
    Icon Selection
    NOTE: The SOS icon cannot be moved.
  4. Use the directional keypad to move the icon on the screen and use the  Check Button to place it.
    Icon Placement
NOTE: To reset to the icons to their original order, press Menu Button and select Reset Icons.
 1 The SOS icon cannot be moved
