Press and hold the top right button.
Select Main Menu.
Select Navigation.
Select Courses.
Select the course you are wanting to use.
Select Ride.
Your course will now be active within this activity.
Most models of Edge® cycling computers have the ability to change the navigation course while the timer is still going. Select your model from the list below to view the steps.
Select Main Menu.
Select Navigation.
Select Courses.
Select Ride.
Tap the screen to bring up the border menu.
Select ![]()
Select Courses,
Select Stop Course.
Select Ride.
Press the back button (bottom right) to return to the home screen.
Select Navigation.
Select Courses.
Select Ride.
Select Yes or No to navigate to the beginning of the course.
These steps are based on your timer already running and a course already having been selected on the device.
Tap the screen to pull up the menu border.
Select
at the bottom of the screen.
Select
option.
Select Courses.
Select Saved Courses.
Select Ride.
Select
Once this is done you can either route to the beginning of the course, or start riding from there as you normally would when starting a course.
Bring up the Home Screen.
Select
Select
Select Ride.
Select
Select
Select
Select Ride.
Select
Select
Select
option.
Select Courses.
Select Ride.
Select
