Getting Started With the inReach SE+/Explorer+
If you are setting up an inReach for the first time, the following steps will walk you through the process to help you get the most out of your new Garmin product.
Setting up the inReach SE®+ or inReach Explorer®+ Outdoor Handheld
When powering on the Garmin handheld for the first time, you will be prompted to configure some settings and activate with an inReach® subscription.
- Power on by holding the
on top of the handheld.
Choose your language by scrolling through the list using
and
buttons, press
to select a language.
Activate your inReach handheld with an inReach Satellite Subscription.
For more help with activation, see - How to Activate a New inReach.
Sync and update your inReach handheld with the inReach Sync.
For more help with updating, see - Updating inReach Firmware and Syncing Account Changes with inReach Sync.
Learn More About the inReach SE+/Explorer+ Handhelds
The following articles will help you explore and use the many features of the inReach SE+/Explorer+ handhelds.
inReach Features
NOTE: Before leaving for a trip, it is recommended to test that you can send out a text message. For instructions, see - Testing Text Messaging on an inReach Handheld.
- inReach Features
- Messaging
- MapShare™, LiveTrack™, & Tracking
- SOS
Connected Features
NOTE: Before leaving for a trip, ensure that you are signed into the Earthmate® app and that the inReach shows as connected in the app when it is powered on and within Bluetooth range.
