Backing up, Restoring, and Transferring Garmin Marine User Data
Before updating the device software, backup user data like waypoints, routes, and tracks. Backing up data should be performed at regular intervals in case any data loss occurs on the device. Backing up the data also provides the ability to edit the information and send it back to the device. There are a few items required to back up the chartplotter's user data:
  • A blank micro/SD card (no larger than a 32 GB* card)**
  • A micro/SD card reader for the computer**
*Devices running system software dated before 2008 will require a micro/SD card no larger than 2 GB.
**The micro/SD card and micro/SD card reader can be purchased from any local electronic store.
To back up the user data
  1. Insert the micro/SD card into the chartplotter
  2. Power on the chartplotter
  3. When the Home screen appears, select Info
    • Chartplotter series menus may vary. See the device's owner's manual for specific directions
  4. Select User Data
  5. Select Data Transfer
  6. Select Card
  7. Select Save To Card
To view the information within BaseCamp™ software
  1. Connect the micro/SD card reader to the computer
  2. Insert the micro/SD card into the micro/SD card reader
  3. Open the BaseCamp™  software
    • On the left side of the application, the GPS device displays
    • A folder called USERDATA will be displayed below the device. USERDATA is the default name given to the folder
    • Future files saved to the same card will prompt for a different file name. The new file name will show under the GPS device in BaseCamp™ software as a folder with the same name
  4. Select the folder containing the user data that lists waypoints, routes, and tracks
To back up the data to the computer
  1. Right-click on the folder from the card that has the user data listed
  2. Select Send To
  3. Select My Collection
This function will copy the user data from the micro/SD card directly to the computer and automatically save it in the My Collection folder.
To restore or transfer user data to a chartplotter
  3. Select Info User Data Data Transfer
    • To transfer data from the memory card to the chartplotter and combine it with existing user data, select Merge from Card
    • To transfer data from the memory card to the chartplotter and overwrite existing user data, select Replace from Card
