Multi-Point Routing using OK Garmin Commands
The Garmin DriveSmart™ 65, 66, 76, and 86 with Amazon Alexa does not support multi-point routing when using the OK Garmin navigation commands. Multi-Point routing is only available with manual entry of locations.
Trying to add a location to an active route using OK Garmin commands will replace the original destination with the new location. However, if the first destination is set using OK Garmin, additional locations can be entered manually.
