Bike Compatibility with Tacx NEO 3M Smart Trainer
The Tacx® NEO 3M smart trainer is designed to fit most modern bicycles, however, there are a select number of bike models known to be incompatible.
The information provided below is not final or comprehensive. It is your responsibility to ensure your bike’s compatibility with this trainer before using the trainer.
CAUTION: Failure to ensure your bike’s compatibility with the trainer could result in damage to your bike or possible personal injury.
NOTICE: The information below is not final or comprehensive. There may be other specific bike models that are not compatible with this trainer or other general aspects of your bike that may make it incompatible with the trainer.
General Guidelines
In addition to specific models that are incompatible, consider the following generalities:
Triathlon/Time-Trial Bikes
Due to the aerodynamic nature of these types of bike frames, some do not have enough clearance between the seat and chain stays.
Disc Brakes
Depending on where the brake caliper is placed on the frame, some calipers may interfere and need to be adjusted.
Eccentric Bottom Brackets or Odd Frame Shapes
These bikes may present challenges to mount.
There may be other general aspects of your bike that may make it incompatible with this trainer.
Bike Models Not Compatible
NOTICE: Other bike models may be incompatible with this trainer.
3T Strada
Argon 18 E-117 Tri+
Argon 18 E-118
Argonaut Space Bike
Bianchi Aquila CV
Bianchi Oltre XR4
BMC Timemachine
BMC Timemachine Road
Canyon Speedmax CF
Cervelo P5X
Colnago Concept
Factor O2
Felt IA Series
Giant Propel Advanced SL
Giant Trinity
Look 795 Blade RS
Merida Warp
Orbea Ordu
Pinarello Bolide TR+
Quintana Roo PRsix
Ridley Dean
Scott Plasma
Specialized Shiv
Trek Speed Concept
Wilier Turbine
