- Log into explore.garmin.com
Select Account at the top of the page.
- NOTE: To access Account on a mobile device, touch the two-line menu icon in the top left corner.
The inReach Address is listed under inReach Addr. in My Info.
The inReach® satellite communicator address is used exclusively to send messages from one inReach to another. The inReach address is derived from the email address of the user and cannot be changed.
The account administrator can see all inReach Addresses for user sub-accounts.
Log into explore.garmin.com with account admin credentials.
Select My Info.
Select Contacts.
Select a Contact.
The inReach Address is listed under INREACH ADDR.
A user with an assigned inReach device and log in credentials for the Garmin Explore™ website can view the inReach Address in their sub-account. Alternatively, the inReach Address can be viewed on the inReach device itself after a successful sync.
Press MENU twice to access the main menu.
Select inReach Utilities.
Select .
The inReach Address is listed below the plan type.
If necessary, press and hold to reach the home page.
Press or
to scroll through the main menu and select SETTINGS
Press or
to scroll through the settings menu and select System
Press or
to scroll through the System menu and select About.
Press or
to scroll to Address.
If necessary, press and hold OK to reach the home page.
Press or
Press or
Press or
Press or
Press OK.
Select Setup.
Select About This Device.
Select Address.
Press OK.
Select Settings.
Select System.
Select About.
Select Settings.
Select inReach Address.
Touch .
Touch inReach.
Touch inReach Utilities.
Touch .
The inReach Address is generated from the portion of the email address used for the inReach user prior to the @, also known as the local-part.
Example: If the email address is peanut.butter@chocolate.com, then the inReach Address assigned to the user would be peanut.butter@inreach.garmin.com.
In cases where there is already another inReach user using an identical local-part, a number is added to the inReach address at the end of the local-part (e. g. peanut.butter1@inreach.garmin.com).
