Garmin Marine micro/SD Card Requirements
Garmin Marine devices use a micro/SD card.
Ensure the micro/SD Card meets the following requirements:
Previous devices use 4 - 32GB*
Current devices use 8GB - 1TB** see New exFAT support on Garmin® Marine Devices
Formatted to FAT 32, or exFAT for devices capable of using larger cards
Class 4 or faster
Refer to Maximum micro/SD Card Capacity to Be Used with Garmin® Chartplotters to determine whether the device utilizes a Micro SD card or a full-size SD card.
*Some legacy chartplotters require software to be above 3.10 to use a 4GB micro/SD card.
** Not all current devices will be compatible with the exFAT format. Refer to New exFAT support on Garmin Marine Devices.
