My inReach Messenger Plus is in the Wrong Language
If your inReach Messenger Plus satellite communicator is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language.
Changing the Language
You may receive prompts to pair and activate before being able to access other settings on the inReach Messenger Plus. If this occurs, scroll to and select the second option in each of these prompts to skip pairing and activation, then proceed with the steps below. Pairing and activation can be completed later from the main menu.
If necessary, press and hold OK to get to the home screen:
Press
or
to scroll through the main menu and select
Select
Press
once, then press OK.
Scroll to and select the desired language.
