Searching for an Address by the ZIP Code on an Automotive Device
The option to search by ZIP code for an address in the US will be displayed after touching Address in the Where To? menu.1
Requirements:
- Some devices require you to change the locale to another country before the postal code (ZIP code) will be an option. (See 'To Change the Device's Locale' steps below).
- To search for a ZIP or postal code, the device must be loaded with mapping that covers all or part of that specific ZIP/postal code.
- On some devices, you may first need to enter the House Number, Country, and/or County/State you're searching in prior to having the option to search for a ZIP/postal code.
- Earlier mapping versions allow you to search by Postal Code within Canada, provided that you have set the device to search in Canada or one of its provinces. Devices must be set as Searching Near a city in Canada to search by Postal Code. For further instructions, see Searching for an Address in a Different City or State on an Automotive Device.
To Change the Device's Locale for Most Models, Refer to the Device's Owner's Manual and Search for Restore Settings, Factory Reset, Reset Default Settings, or Resetting Data.
To Change the Device's Locale for the Following Devices, a Factory Reset is Necessary:
- Arctic Cat G8 Display,
- Camper 890 | Camper 895 | Camper 1090 | Camper 1095 caravan and motorhome sat navs
- RV 890 | RV 895 | RV 1090 | RV 1095 RV navigators
- dēzl™ 780 LMT-S | dēzl™ LGV800 | dēzl™ OTR800 | dēzl™ LGV810 | dēzl™ OTR810 | dēzl™ LGV1000 | dēzl™ OTR1000 | dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
- dēzlCam™ 785 LMT-S GPS navigator with camera
- Kawasaki RIDGE® 8" Tread Display
- Tread® - Overland Edition, Tread® XL - Baja Chase Edition, Tread® XL - Baja Race Edition, Tread® XL - Overland Edition, and Tread® - SxS Edition GPS navigators
To Perform a Factory Data Reset:
- Open the device's Settings menu
- Touch Apps first then touch Tools on some devices
- Touch Personal
- Some devices skip this step
- Touch Device Reset
- Touch Factory data reset or Erase all data
- Touch Reset Device
- Touch Erase Everything or Reset Device
1This applies to City Navigator North America NT 2012.10 maps or newer.
