The Varia Radar or Headlight Does Not Automatically Reconnect to the Varia App
WARNING! If the Varia RTL does not automatically reconnect within a period of 30 seconds after losing the device connection, or send data to the Varia app, we recommend that you stop riding and check the devices in a safe location. Failure to do so could result in serious injury or death.
The Varia™ app will indicate a device is paired with a green dot next to the device icon in the app. If the dot is grey, or there is a message saying "Bluetooth connection lost" the Varia is not connected to the app. Try the following troubleshooting steps:
Turn the Varia off and back on using the power device key.
Turn your phone's Bluetooth off and back on.
Exit and enter the Varia app.
You can check the battery level when you turn the devices back on.
Remove the Varia radar from the list of paired devices and pair it again.
NOTE: The Varia™ UT800 light and Varia™ RTL510 radar are not compatible with the Varia app.
