Checking Battery Life on the Approach R50
To check the battery level on the Approach® R50 launch monitor it needs to be powered on.
Checking the Battery Level
Press the menu button in the bottom right corner.
Select Settings.
Select Battery and Power.
Here you can see the battery life percentage as well as the estimated battery life remaining.
