Garmin Sonar Module Compatibility
Note:  Ensure sonar modules are up to date on software for full compatibility listed below.
Garmin® sonar modules are devices that provide sonar to chartplotters that do not have built-in sonar capability or add additional sonar options that may not have been included in some chartplotters' built-in modules, such as side scanning sonar.
See the module's installation instructions for more information about network connections.
Chartplotter / Sonar Module Compatibility
GPSMAP® Chartplotter / Sonar Module Compatibility
GSD™ 24 Advanced Sonar ModuleGSD™ 25 Premium Sonar ModuleGSD™ 26 CHIRP professional sonar module GSD™ 28 Sonar ModuleGCV™ 10
Scanning Sonar Black Box
GCV™ 20
GLS™ 10 Sonar Module
GPSMAP® 5x7 chartplotter
GPSMAP® 7x1 chartplotter
XX
GPSMAP® 7x2 /  9x2 chartplotterXXX
XX
GPSMAP® 10x2 /  12x2 chartplotterXXXXXX
GPSMAP® 7x3 /  9x3 /  12x3 / 16x3 chartplotterXXXXXX
GPSMAP® 8x0 / 10x0 chartplotter
XX
GPSMAP® 4xxx / 5xxx / 6xxx /  70xx / 72xx chartplotterX
X
GPSMAP® 74xx / 76xx chartplotterXXX
XX
GPSMAP® 80xx / 82xx        chartplotter
GPSMAP® 8500 Black Box
XXX
XX
GPSMAP® 84xx /  86xx    chartplotter
GPSMAP® 8700 Black Box
XXXXXX
GPSMAP® 90xx / 92xx        chartplotter
GPSMAP® 9500 Black Box
XX
¹ Requires use of BlueNet™ 30 Gateway for compatibility When To Utilize a Garmin BlueNet 30 Gateway
² This device cannot display SideVü™ scanning sonar
³ These devices are only compatible with the GLS 10 with the Livescope™ 32 transducer connected to the black box.
Echomap™ Chartplotter / Sonar Module Compatibility
GCV™ 10 scanning sonar module GCV™ 20 scanning sonar module GLS™ 10 Sonar Module
echoMAP™ 50s / 70s chartplotter    echoMAP™ 70dv chartplotter          XX
echoMAP™ 50dv chartplotter
ECHOMAP™  Plus 7x chartplotter    ECHOMAP™  Plus 9x chartplotter   XX
ECHOMAP™ UHD 7 chartplotter        ECHOMAP™  UHD 9 chartplotter      XXX
ECHOMAP™ UHD2 7sv
ECHOMAP™ UHD2 9sv chartplotter
X
ECHOMAP™ Ultra chartplotter         XXX
ECHOMAP™ Ultra 2 chartplotter
XX
¹ This device cannot display SideVü™ scanning sonar
² These devices are only compatible with the GLS 10 with the Livescope™ 32 transducer connected to the black box.
Discontinued Chartplotter Compatibility / Discontinued Sounder Module
GSD™ 20 sonar module
Connects using Serial (S) Connection
GSD™ 21 sonar module
Connects using Serial (S) or CANet (C) Connection
GSD™ 22 digital remote sounder
Connects using CANet (C) and Marine Network (X)
GPSMAP® 1x2 /  178 chartplotter  SS
GPSMAP® 1x2c / 178c chartplotterSS
GPSMAP® 232 / 238 chartplotter    SS
GPSMAP® 276c / 376c chartplotterSS
GPSMAP® 296 / 396 chartplotter    SS
GPSMAP® 378 / 478 chartplotter     SS
GPSMAP® 20xx                                    SS
GPSMAP® 292, 392, 492 chartplotterSS / CC
GPSMAP® 4x0 / 5x0 chartplotter       SS / CC
GPSMAP® 4x5 / 5x5 chartplotter       SS / CC
GPSMAP® 21xx / 22xx chartplotter SS / CC
GPSMAP® 3xxx chartplotter             SSX
X
X
GPSMAP® 80xx / 82xx / 85xx chartplotter
X
Transducer / Sonar Module Compatibility
Ice Fishing
Ice fishing transducers are not compatible with sonar modules.
In-Hull
Garmin®
GSD™ 24 Advanced Sonar ModuleGSD™ 25 Premium Sonar ModuleGSD™ 26 CHIRP professional sonar moduleGSD™ 28 Sonar ModuleGCV™ 10
GCV™ 20
GT8HW-IH
X
GT15H-IH
X
Airmar®
GCV™ 20
P72                                         X
P75M
X
P79                                          X
P95M
X
M135M Chirp-ready In-hull
X
M260                                       XXX
M265LH
XX
M285HW
X
R111 (LH, LHW)
X - LH OnlyX
R199                                        X
R599 (LM, LH)
XX
¹ 12-pin, dual-channel CHIRP only
Pocket-Mounted
GSD™ 24 Advanced Sonar ModuleGSD™ 25 Premium Sonar Module 25GSD™ 26 CHIRP professional sonar moduleGSD™ 28 Sonar ModuleGCV™ 10
GCV™ 20
Airmar® CM599 (LM, LH, LHW)
XX
Airmar® PM265 (LM, LH)
XX
Airmar® PM411LWM
XX
Thru-Hull
Garmin®
GCV™ 20
GT12M-THF
XXX
GT15M-THF
XXX
GT17M-THF
XXX
GT21-TH
X
GT23M-TH
X
GT30 (TH, THP)
XX
GT34UHD (TH, THP)
X
GT51M (TH, THP)
Panoptix LiveScope LVS32-TH
X
¹ Transducers only compatible with the 12-pin transducer port
Airmar®
GCV™ 20
B45 narrow stem            X
B60                                    X
B75 (H, L, M, HW)
XXX
B117                                   XX
B150M
XXX
B164                                  XX
B175 (HW, H, L, M, MW)
XXX
B258                                  XXX
B260                                  XXX
B265 (LH, LM)
XX
B275LHW
XXX
B619                                  XX
B744 (V, VL)                      XX
P19
X
P319                                  XX
R99                                    X
R109 (LHW, LH, LM)
X (No LM)X
R409LWM
X
509LHW
XX
R509 (LM, LH)
XX
SS60                                  XX
SS164
X
SS260
X
SS502                                XX
B765
X
¹ Must be set to 50|200 kHz (500 W) and can not be used with the GT 30
² Transducer only compatible with the 12-pin transducer port
Transom or Trolling Motor-Mounted
Garmin®
GCV™ 20
Dual Beam (4-pin)¹
Dual Beam (8-pin)
X
Dual Frequency     XX
GT8HW-TM
X
GT15M-TM
X
GT20-TM (4-pin)¹
GT20-TM
X
GT21-TM
X
GT22HW-TM
X
GT23M-TM
X
GT24UHD-TM¹
GT30-TM
XX
GT34UHD-TM
X
GT36UHD-TM
X
GT40M-TM
X
GT41-TM
X
GT50M-TM
X
GT51M-TM
GT52HW-TM
GT54UHD-TM
X²,³
GT56UHD-TM¹
Panoptix LiveScope™ LVS32 Transducer
X
Panoptix LiveScope™ Plus LVS34
X
Panoptix LiveScope™ XR LVS62
X
¹ These transducers not compatible with any external sonar modules
² Transducers only compatible with the 12-pin transducer port
³ 1200 kHz SideVu not supported
Airmar®
GCV™ 20
P32 triducer
X
P66 triducer       XX
TM150M
XXX
TM165HW
X
TM185 (M, MW)
XXX
TM260                X
TM265 (LH, LM)
X - LH OnlyX - LH OnlyX
