Creating Custom Points of Interest (POI) Categories on an Automotive Device
Custom Points of Interest (POIs) will display in categories when you load them to your device using the Points of Interest (POI) Loader program.
To Create Custom Categories to Sort These POIs on Your Device:
  1. Create a clearly-named folder in an easy-to-find location on your computer (for example, a folder labeled POI on your desktop)
  2. Create additional folders within the POI folder
  3. Give each of these subfolders the name of a category you'd like displayed on the device
  4. Save all the desired custom POI collections to the appropriate subfolder
  5. Run the POI Loader application
  6. Select the POI folder created in step 1 when asked to select the folder where the data files can be found
The POI Loader will transfer all the custom POI files from the subfolders created in step 2. The category names on the device will match the names of the subfolders created in step 2.
