Downloading BirdsEye Direct Satellite Imagery on the zūmo XT or zūmo XT2
BirdsEye Direct Satellite Imagery provides downloadable high-resolution map imagery, including detailed satellite imagery and topographical maps.
  • A subscription is not required and coverage is worldwide.
  • You can download BirdsEye Direct Satellite Imagery directly to your device when it is connected to a Wi-Fi network.
    • See the owner's manual of your device for instructions to connect to Wi-Fi.
  • Birdseye Direct Satellite Imagery is locked to one device and cannot be transferred to another device even if using a memory card.
  • The zūmo XT and zūmo® XT2 GPS navigators can accept up to 250 separate BirdsEye files as long as there is memory available.
    • Device functionality may be slowed as the number of BirdsEye files increases due to the amount of data the device needs to manage.
    • Consider removing infrequently used images if performance is impacted.
  • Garmin offers the most recent images that our BirdsEye providers make available.
  • You can typically expect an update once a year in heavily populated areas. An update can usually be seen every two years in lesser populated areas. Updates to less populated areas do not apply to all regions, some regions may experience longer time-frames between updates.
    • These time-frames are estimated and there is no notification when an area will be, or has been, updated.
Watch this Helpful Video or See the Steps Below.
To Download BirdsEye Direct Satellite Imagery for the zūmo XT
1. Touch Apps
2. Touch BirdsEye Direct
3. Touch the Download icon
4. Touch Location and use the search options if you want to download a specific location
  • The default is your current location.
5. Touch Detail to select an image quality option. Select an option and touch Save.
6. Touch Size to enter the size of the area to be shown in the downloaded imagery files. Enter a distance from the selected location and touch Done.
  • The maximum size of BirdsEye area depends on the location and detail level set.
7. Touch Save To if you want to select a specific location to save the file. Select an option and touch Save.
8. Touch Download
9. Enter a name and touch Done
To View Downloaded Satellite Imagery in the BirdsEye Direct App:
1. Touch Apps
3. Touch the name of the BirdsEye Imagery download you wish to view
4. BirdsEye Imagery is then shown with information on file size, storage location, and detail level.
To Download BirdsEye Direct Satellite Imagery for the zūmo XT2
1. Touch Apps
8. Touch Download
1. Touch Apps
Related
