Powering the Approach R10 on or Off
The Approach® R10 launch monitor has a single button located on the back of the device. Press the button once1 to turn the device on. Press and hold the button for one second to turn the device off.
1 The button only needs to be pressed briefly in order to power the device on. Pressing and holding the button while the device is powered off may prompt it to go into pairing mode, which will be indicated by a blue status LED on the front of the device.
