How to Reset the Rino 750 or 755t
There are a few instances in which it is necessary to perform a full reset on a Rino® 750 or Rino® 755t outdoor radio, including the following:
- Not receiving a satellite signal
- Restoring the factory default settings
- Not functioning properly
The information and steps below will walk you through backing up your data and resetting.
Before Resetting
Performing a full reset can cause user data loss. User data is waypoints, routes, tracks, activities, contacts and geocaches.
It is recommended to back up important data with BaseCamp™ software before resetting. For steps, see Related.
Note: Contacts cannot be backed up and will be erased during a reset. Contacts can be re-added by accepting the prompt to save the contact once the other device has initiated a transmission.
If removing data is desired to eliminate corrupt data or free up space, see Related.
Performing a Full Reset
- Power the Rino off
- Press and hold Call
(found on top left of the device)
- Power the device on while still holding down the Call button
- Release the Call button when you see the Erase all user data? message
- Touch Erase
The Rino has now been reset. You will want to take the device outside in a clear view of the sky for a minimum of 20 minutes to re-acquire satellite data.
Reset with Device Stuck at Garmin Logo
- Press and Hold: Call, Volume Up & Volume Down Buttons
- While holding the button combo: Press the Power Button
- Release all the buttons when the Garmin logo appears
The Rino should produce a beep and load the Main Menu
