Marine Devices with a Chassis Ground Screw
Many Garmin marine devices have a chassis ground screw to help prevent electrical interference. A marine-grade copper solid or stranded wire should be connected at the chassis ground and taken to the water ground. Examples of “water ground” could be found in different circuitry, wires, and connections to different systems of the vessel. Refer to the vessel's electrical distribution system to identify them or contact the vessel manufacturer. 1 Highly recommended for touchscreen devices.
Bonding a marine device (chartplotters, sounder modules, etc.) using the device's chassis ground provides some protection to the internal circuits and components from directly induced electrical currents.
NOTE: Bonding a marine device using the chassis grounding point may not stop or prevent damage caused by a lightning strike.
Below is a list of the screw sizes, and corresponding units for each type and size of screw:
M3x0.5x4.0,PHP,SS/P,Nylon
echoMAP 70 / 70s / 70dv
ECHOMAP Ultra Series
GPSMAP 7x1 / 7x1xs
GPSMAP 7x2 / 9x2 (Plus)
GPSMAP 10x2 / 12x2 (Plus)
GPSMAP 74xx / 76xx
GPSMAP 84xx / 86xx
M3x0.5x6.0,PHP,SS/P,Nylon
GMM 150 / 170 / 190
GPSMAP 8xxx
GPSMAP 8500 / 8530
M4x0.7x5,PHP/S,SS/P
STRIKER 7 / 9
STRIKER Plus 7 / 9
- STRIKER Vivid 7 / 9
M3x0.5x8.0,PHP LW/W
AIS 600
VHF 100
VHF 200
VHF 300
VHF 300 AIS
M3x0.5x10.0,PHP,SS/P,Nylon
GSD 24
GSD 26
M4x0.7x6,PHP,SS/P,w/Nylon
GMR 424 / 426 xHD2
GMR 624 / 626 xHD2
GMR 1224 / 1226 xHD2
GMR 2524 / 2526 xHD2
M4x0.7x8,PHP,SS/P,w/Nylon
- GMR Fantom pedestals
Terminal Ring, 18-14 AWG #6 Solid or Stranded Copper Wire Panduit-2176
- LiveScope GLS 10
1 On a marine vessel, the DC ground or electrical bond may also be referred to as a "water ground". Refer to the vessel's electrical distribution system to identify them.
