Is it Possible for my Application to add Via/Intermediate Points to a Current Active Route?
It is possible for your application to add a via/intermediate point to a current active route via fleet APIs. A via/intermediate point is equivalent to a destination point where the device will provide navigation to the inserted point and the driver will receive an announcement.
Before you can shape your route, you must start a route. See the owner's manual for additional instructions.
You can manually shape your route to change its course. This allows you to direct the route to use a certain road or go through a certain area without adding a destination to the route.
1. Touch anywhere on the map
2. Select
The device enters route shaping mode.
3. Select a location on the map
Tip: You can select the to zoom in on the map and select a more precise location.
The device recalculates the route to travel through the selected location.
4. If necessary, select an option:
To add more shaping points to the route, select additional locations on the map.
To remove a shaping point, select .
5. When you are finished shaping the route, select .
