I Am Seeing a Not Enough Memory Error for My Edge 540 in Garmin Express
Seeing a "Not Enough Memory" error in the Garmin Express™ program when installing initial map updates on your an Edge® 540 cycling computer, is likely due to the inclusion of the Navigation Free ClimbPro maps which require additional space. To resolve this error, use Managing Maps in Garmin Express to deselect one of the regional maps or keep an entire region and a subset of another region enabled, provided there is sufficient storage on the device.
To Remove a Regional Cycling Map
Connect your device to your computer with the USB charging cable.
Launch Garmin Express.
Select your device.
Select Manage Maps.
Un-check the map you want to remove.
Select Apply Changes.
Once the regional cycling map is removed, you will now have the enough memory to enable a subset of another region on the Edge.
To Enable a Map Region
Remove then reconnect the Edge to your computer with the USB charging cable.
Select your device.
Select Manage Maps.
Select Change Region below the map region you wish to add.
North America has the following options:
Routable Cycle Map of Canada/Alaska
Routable Cycle Map of Middle America
Routable Cycle Map of the United States
Europe has the following options:
Routable Cycle Map of Central Europe
Routable Cycle Map of East Europe
Routable Cycle Map of West Europe
Select a region.
Select Confirm.
Select Continue.
