Adding a Via Point to a Route on an Automotive Device
When you set up a via point on a route, the device navigates to your final destination by way of the via point that you added. In other words, you navigate first to the via point, and then to your final destination.
To Add a Via Point to a Route:
  1. Touch a destination
  2. Touch Go!
    • It may be required to allow the device to calculate to this destination before moving on to the next step
  3. Touch the menu button or back arrow to return to the main menu
  4. Touch Where To? or Search
  5. Locate and touch the desired Saved, Point of Interest, Address, or Recent location
  6. Touch Go!
  7. Touch Add as Next Stop or Add as Last Stop
The device will now navigate to the newly entered point during the route.
Note: You can add several via points per route.
