What should I do if one of my databases is not syncing between panel mount devices in my aircraft?
First, make sure that Database Sync is enabled in your system. If it is, navigate to the Standby folder within the Systems page to check if the databases are syncing. If it shows that they are done syncing, power cycle the avionics. If after power cycling the avionics, a database is still not syncing from one panel mount device to another, we recommend downloading the database(s) . Once the download is complete, place the SD Card in the device in the aircraft and let it update.
Related
