Determining if a Hydraulic Steering Cylinder is Balanced or Unbalanced
One major factor when purchasing and installing an autopilot is to know if the hydraulic steering system is balanced or unbalanced. If the steering system is unbalanced, an unbalanced kit may need to be purchased (depending on the pump needed).
Balanced/unbalanced systems are differentiated by the difference in the amount of hydraulic fluid it takes to steer in one direction than the other. A balanced system will use the same amount of fluid to turn in both directions. An unbalanced system will require less fluid to steer the engine/rudder in one direction than the other. To identify what type of system is on a vessel, the steering cylinders will need to be examined:
  • Balanced cylinders have a rod extending from both ends of the cylinder.
  • Unbalanced cylinders have a rod extending from only one end of the cylinder.
Two unbalanced cylinders can make up a balanced system as long as the unbalanced cylinders are opposing one another. See examples below
Another quick test is to steer the boat hard-over from port to starboard and count the number of turns. Now, count the number of turns it takes to go from hard-over starboard to port. If the number of turns differs considerably in one direction than the other, the system is unbalanced. A balanced system will require the same amount of turns in either direction.
Single engine unbalanced above dual engine unbalancedSingle engine balanced above dual engine balanced
