Fuse Size Used by the Garmin Marine Radar Power Cable
Garmin radome radars use a 7.5A fuse in the power cable of the radar. The radome radars that use this fuse are:
  • GMR 18
  • GMR 18HD
  • GMR 20
  • GMR 21
  • GMR 24
  • GMR 24HD
  • GMR 40
  • GMR 41
Garmin open-array radars actually use two fuses. The first fuse is found in the cable that connects the radars pedestal to the voltage converter. This is a 7.5A fuse. The second fuse is found in the cable that connects the voltage converter cable to the power source of the boat. This is a 15A slow blow fuse. The open-array radars that use these fuses are:
  • GMR 404
  • GMR 404 xHD
  • GMR 406
  • GMR 406 xHD
  • GMR 604 xHD
  • GMR 606 xHD
  • GMR 1204 xHD
  • GMR 1206 xHD
