Missing Widget on a Tread Device
Your device has a customizable home screen. The widgets can be moved to different places on the home screen or removed completely. If you have accidentally removed any of the widgets, they can be replaced.
To Replace a Widget:
1. Hold your finger down on the home screen in the empty space
2. Touch Widgets
3. Touch and hold the widget you wish to use
4. Drag the widget to the desired place on the home screen
You will now have the option to select the widget.
