Syncing the inReach Mini 2 With the Garmin Explore Website and App
The inReach® Mini 2 satellite communication device can be used with or without an inReach subscription. Both result in a different experience when the handheld is used with the Garmin Explore™ website and Garmin Explore™ app (for more information, see - Garmin Explore App Overview and Overview of the Garmin Explore Website).
The Garmin Explore app acts as the go-between for the Garmin Explore website and the handheld. The app and website are used to create, manage, and view recorded user data (waypoints, routes, tracks, and activities).
When paired and connected, the handheld, website, and app regularly communicate with each other. When the app syncs, it sends and receives user data between the website and the handheld. With an inReach subscription, the app also syncs account changes made on the website such as Check-In Messages (formerly known as Preset Messages), Contacts, and other items to the handheld.
Even if you only ever use the app, the website is the cloud storage for data synced from the handheld through the app.
NOTE: It is not possible to sync messages from the Garmin Explore website inbox to the Garmin Explore app. There may be instances where they have been deleted such as transferring service from one device to another, or resetting a device.
Pairing With the Garmin Explore App
Before you can sync, you must first pair your handheld with the Garmin Explore app. Pairing instructions can be found in the following article: Pairing an inReach Mini 2 With the Garmin Explore App.
Syncing With the Garmin Explore Website and Garmin Explore App
IMPORTANT: You must use the Garmin Explore app to sync data to and from the handheld, the inReach Sync application is not compatible.
When the Garmin Explore app is opened or refreshed, it automatically syncs between the Garmin Explore website and the paired inReach device when it is powered on. It can take a few moments for both to complete.
However, syncs can also be performed manually with the steps below. Syncing manually can be useful for sharing newly created data or changes between the Garmin Explore app, Garmin Explore website, and inReach device.
Important Notes
    • Ensure the same account is logged into on the Garmin Explore app that is also used on the Garmin Explore website.
    • The paired mobile device needs a data connection to sync to and from the Garmin Explore website.
    • To sync to and from the Garmin Explore app, the inReach device needs to be powered on and in range (about 10ft) of the paired mobile device.
Syncing Manually
    1. Open the Garmin Explore app.
    2. TouchOrange Icon of Watch and Handheld Device.
    3. Touch Circular Orange Arrows to Sync in the Garmin Explore App next to the inReach device.
    4. Wait for the sync to complete.
Garmin Explore app will update the time of the last sync after the sync has completed.
Items That Sync Between the Paired Device, Garmin Explore Website, and Garmin Explore App
NOTE: When a device is suspended the inReach services are inactive, this means the inReach capabilities will cease to function (messaging, SOS, inReach Weather, etc.), but all other aspects of the device still work. As such, it can still sync with the Garmin Explore app and website while suspended.
Items That Sync Without an inReach Subscription
From the inReach Mini 2 to the Garmin Explore App and Website
  • Activities
  • Waypoints
From the Garmin Explore App and Website to the inReach Mini 2
  • Collections
  • Courses
  • Routes (Sync over as Courses on the inReach Mini 2)
    • May be limited to 20 routes per Collection
  • Tracks (Sync over as Activities on the inReach Mini 2)
    • May be limited to 5 tracks per Collection
Items That Sync With an Active inReach Subscription
  • Activities
  • Waypoints
  • Collections
  • Contacts
  • Courses
  • Check-In Messages (formerly known as Preset Messages)
  • Quick Text Messages
NOTE: The inReach Mini 2 device does not have the ability to sync the entire library and must use specific collections. For more information on using Collections, see - Managing Collections on the Garmin Explore Website Map Page.
