Getting Started With the tactix Delta
If you are setting up a tactix Delta for the first time, the following steps walk you through the process to help you get the most out of your new watch.
Setting Up the tactix Delta
When powering on the watch for the first time, you will be prompted to configure your user setting and preferences on the watch. These settings can be changed at any time.
1. Power on the watch by holding Light
Click Here to Learn About the Buttons
tactix Delta Buttons
one instruction LIGHT
  • Press to turn the backlight on and off
  • Press to turn the device on
  • Hold to view the controls menu
two instruction UP/MENU
  • Press to scroll through the widget loop and menus
  • Hold to view the menu
three instruction DOWN
  • Hold to view the music controls from any screen
four instruction START/STOP
  • Press to view the activity list and start or stop an activity
  • Press to choose an option in a menu
  • Hold to save your current location using dual grid coordinates
five instruction BACK/LAP
  • Press to return to the previous screen
  • Press to record a lap, rest, or transition during a multisport activity
  • Hold to view the watch face from any screen
2. Choose your language by scrolling through the list using Up and Down, press Start to select the language
3. Pair the watch to your smartphone with the Garmin Connect app (optional)
Click Here for Help With Bluetooth Pairing
4. Proceed through the onscreen prompts to select your preferences and user settings
Learn More About the tactix Delta
The following articles will help you explore and use the many features of the tactix Delta:
Tactical Features
Connected Features
Music Features
Battery Features
Training Features
Customizing the tactix Delta
