Pairing a Bike Sensor to the Forerunner 620
The Garmin Speed/Cadence Sensor (GSC 10), Bike Speed Sensor (BSS), and Bike Cadence Sensor (BCS) will pair to the Forerunner 620 when the watch is in the Ride activity profile.
Select the Ride Profile
  1. Select Clock icon bottom left Forerunner 610 (bottom left).
  2. Select the screen to unlock the device.
  3. Select 3 lines on Forerunner 620.
  4. Select Settings.
  5. Select Activity Profiles.
  6. Select Ride.
Pair Sensors
  1. Select clock icon bottom left forerunner 610 (bottom left).
  4. Select Settings.
  5. Select Sensors.
  6. Select Add Sensor.
  7. Select Bike Sensor.
  8. Activate your Sensors by spinning the crank and tire.
  9. Once the watch displays "Bike Sensor Found", the watch and sensor(s) are paired.
Now that your sensors are paired, the watch will automatically recognizes the sensors during your next rides. Whenever you change the battery in your bike sensor(s), the above steps will need to be repeated in order to pair to the watch again.
