My Oregon 700 Series is in the Wrong Language
If your Oregon® 700 series outdoor handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below, see Related for steps to reset the handheld. You will be prompted to select a language after the reset, during initial setup.
Changing the Language
Steps will vary slightly depending on which display mode the handheld is set to.
Activity Mode (Default)
- If necessary, tap
until you reach the home screen:
- Tap
- Tap
. - Tap the second item in the menu.
- Tap the desired language.
Classic Mode
- If necessary, tap
- Swipe up from the bottom of the screen to open the application drawer.
- Tap
. - Tap
