Cannot Calibrate Past the First Aim Point - Stuck in a Loop
If during the calibration process for the Xero® X1i crossbow scope you appear to be stuck in a loop and cannot calibrate past the first aim point, it may be due to using the Trigger Button as the OK button. This is not the intended purpose. The trigger button is only designed to be used for ranging targets and bringing up fixed aim points. If the sight is asking you to select an option, use  the OK button on the scope. Do Not use the Trigger Button in an attempt to select any option from the display.
To get out of the loop, start using the OK button. If the issue persists, press and hold the OK/PWR button until the device powers off, then power the Xero X1i scope back on.
For more information on the device, please review the owner's manual.
