Troubleshooting an Edge 500 Not Acquiring Satellite Signal
Occasionally, satellite data can become obsolete or corrupt preventing the Edge 500 from acquiring a satellite lock. Performing an AutoLocate on the device removes all of the current satellite data and allows it to re-establish a proper connection with satellites.
An AutoLocate may also be necessary in the following circumstances:
Device has not been used in over two weeks.
Device is powered on in a location that is 150 or more miles from where it is normally used.
Distance or speed data appears to be inaccurate as a result of a corrupt satellite signal.
To perform an AutoLocate:
Ensure the device is powered off.
Press and hold Lap and Start.
Press Power.
Release Lap and Start when the Garmin screen appears.
Leave the device outside with a clear view of the sky for a minimum of twenty minutes.
Edge 500 will now have current satellite data, providing a good satellite lock. This will decrease the chance of inaccuracies in distance or speed.
