Using TracBack on a Colorado Series Device
On the Colorado® series handheld devices, Tracback® routing can only be performed using the current track log. If a saved or archived track is chosen, the Tracback routing option will not appear.
To perform TracBack routing on the Colorado series handhelds:
- Access the Shortcut Menu
- Select Where To
- Select Tracks
- Select Current Track
- Press Enter when the Green TracBack button appears
- Begin Navigation
Your device will now navigate back along the previously recorded track. Both the Compass and Map page can be utilized in following the track.
